Re: MUFFLER
Posted by Harold H on August 08, 2005 at 12:31:39 from (67.141.169.26):
In Reply to: MUFFLER posted by MITCHP on August 08, 2005 at 12:05:32:
Sounds like you have too much back pressure. Although you had the inlet pipe expanded to fit, it is still smaller above where it was expanded. This could eventually cause you valve problems. If you still want to keep the smaller muffler, you might could wrap muffler tape under the clamp. In the long run, you will probably be better off cutting off the vertical pipe of a correct muffler. This will lower your height but still allow the exhaust to breath properly.
Harold H
Post a Followup
