Re: MUFFLER
Posted by Andy Martin on August 08, 2005 at 13:25:34 from (64.219.39.195):
In Reply to: MUFFLER posted by MITCHP on August 08, 2005 at 12:05:32:
Sounds like the muffler shop may have expanded the pipe too much.
If you don't have a clamp on it, put one on. A standard muffler clamp will bend the metal back to make a tight fit.
I'm not sure what a "cob job" is but I do know you are taking a reasonable course to get the tractor to fit into your space. Nat gets a little twisted and comes across as belittling someone instead of helping with their problem. I just wish I knew as much about these old tractors as he does. Usually he does give good advice when he gets around to it.
I highly doubt that if the muffler really is too small that the muffler shop could have expanded it enough. There is a limit as to how much you can stretch them.
Post a Followup
