Re: 574 TRANS.
Posted by Bernard le mécano on August 08, 2005 at 17:05:58 from (207.134.202.169):
In Reply to: 574 TRANS. posted by irving. on August 06, 2005 at 17:04:39:
Hi Irving, i have changed many of those parts, at the Case-IH dealer, where I have worked for. You can remove the lever and replace it by the left side of the rear train. Just train the oil, remove the MCV control valve ( the plate that hold the hydraulic pump and filter) With a short 7/8 open wrench, loose the sealed nut, remove the broken shaft and place the new one. It have a big spline for the timing. Just aling the short lever with the fork.
Bernard le mécano Québec Canada
Post a Followup
