Re: MUFFLER
Posted by CNKS on August 08, 2005 at 17:44:15 from (204.249.178.138):
In Reply to: MUFFLER posted by MITCHP on August 08, 2005 at 12:05:32:
I believe OEM Tractor Parts has an original type clamp that is wider. You can also reduce the leak by using a small piece of sheet metal between the exhaust pipe and the muffler. I don't believe I would try to put the clamp below the hood. I don't think it would fit and you will just mess up your hood removing the muffler when you need to remove the hood. There are a few nasty comments below, just ignore them. If you have to get it in the basement, there is only so much you can do. You would be better off if you could at least find a muffler that fits the pipe.
Post a Followup
