Re: 6V generator/regulator woes
Posted by Hermit on August 08, 2005 at 20:54:56 from (69.21.48.30):
In Reply to: 6V generator/regulator woes posted by Georgia Boy on August 08, 2005 at 16:57:34:
If you have a three brush generator, the third brush is used to adjust the amperage output. Did you install the new brushes with the pre-cut angle going the right direction? Did you seat the brushes with sandpaper or seating compound? Is the voltage output at the generator per specs?
An old battery wouldn't cause this malfunction.
Post a Followup
