Re: Rear axle bearing replacement on an H
Posted by Aces on August 09, 2005 at 05:07:28 from (67.0.20.150):
In Reply to: Rear axle bearing replacement on an H posted by Dave in CT on August 08, 2005 at 23:51:28:
Dave I did nit read all you have listed. But 1 & 2 are right. Remove the wheel and housing end cap and PTO. Now through the PTO hole remove the cap screw from the end or the axel and take the wasker off the screw, put the screw back into the axel all the way get a hard block of wood or a shaft that will fit between the left and right axel screws. Now as you screw the capscrew back out it will bush the axel out of the housing. The end cap holds the outer bearing no retainer. In # 3 for get the nut under the bull gear. You said axel bearing so I don't know what carrier you are talking about. Behind the bull gear there is a retainer for the inside bearing. You will have to pull the bull gear back and move it to the other side to get in behind the gear to get at the retainer. If I where to do this job I would remove the axel housing for inside bearing. When you go back together you will need a bar to lift the bullgear some to get the axel to go into the gear, if you don't remove the housing you will need to move the bull gear back and to the other side as best as you can that's why I say forget anything under the gear cause you need to move it.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
