Re: Glow Plug D282
Posted by Bob on August 09, 2005 at 06:46:54 from (64.21.249.40):
In Reply to: Glow Plug D282 posted by Robhkent on August 08, 2005 at 18:23:14:
The glow plugs can easily be accurately tested in place. It is hard to get an accurate resistance reading when very low Ohms values are encountered, but EASY to get a current draw reading. Current draw is what makes the heat!!! I use an old SUN automotive diagnostic DC ammeter, but if you don't have such a device, simply grab a spare ammeter (such as is used in a tractor dashboard). (30-0-30 or 60-0-60) Put 2 leads on it with alligator clips. Disconnect the power feed wires from all the glow plugs. Connect one clip to the battery's (+) post and touch the other clip to each glow plug in turn. (The meter will read either charge or discharge, depending upon how you've connected the clips. If it reads discharge, you can reverse the clips, for a conventional positive reading, although the actual amperage reading should be the same in either direction.) Take note of each glow plug's current draw, and compare them. Compare the draw to a new one, also, if desired. (Just to be safe, don't power up a glow plug for more than a few seconds at a time, as on certain models several may be connected in series, and will overheat, if powered by a full 12 Volts for an extended length of time. The working glow plugs will usually all draw close to the same amperage, and the "dead" ones will almost always draw "0" Amps. I use this method on a daily basis on Ford (IH) and GM pickup diesel engines, and we get an ocassional 706 or 424 through here, and the method works well with the Binders, too.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
