Re: M -- My oil and temp gauges kaput
Posted by captaink on August 09, 2005 at 14:25:45 from (66.115.214.56):
In Reply to: M -- My oil and temp gauges kaput posted by E-manhunt on August 09, 2005 at 13:33:56:
Check to see if the oil presure line is plugged. I'd take it off at the block and blow it out and make sure that the port is open. As far as the temp guage, if it is the factory one with the bulb on the end it might be working and indicating that your engine is not warming up as it should possibly
Post a Followup
