Re: 6 volt starter fixed success!!
Posted by Haas on August 10, 2005 at 18:36:23 from (12.65.19.162):
In Reply to: 6 volt starter fixed success!! posted by Leee on August 10, 2005 at 05:24:50:
You may want to take your starter to a starter repair shop and have them replace the contact button. I had a C that the starter would not work, even though it had been converted to 12 volt. Turned out the "button" had eroded over the years to the point the switch would not make sufficient contact. New button, problem gone.
Post a Followup
