Re: Grandpa's Cub
Posted by Rudi on August 11, 2005 at 18:49:37 from (69.195.156.80):
In Reply to: Grandpa's Cub posted by Duane M. Duvic on August 11, 2005 at 12:31:55:
Duane:
Rusty is correct, it is a 1953 and the J does indicate that it has a Rockford Clutch. Tractors without the J would indicate that they have an Auburn Clutch.
This suffix was used to indicate which tractor had which clutch, so that the IH Techs at the time would be able to order the correct parts without splitting the tractor to determine which clutch was in it.
You can find that information on the Cub Manual Server at www.cleancomputes.com/Cub/index.html under the Cub Parts Manuals, TC-37F Revision 2, Suffix Letter Code.
Hope this helps
Post a Followup
