Re: IH 460 carb problem
Posted by Walt Stein on August 12, 2005 at 04:33:33 from (172.129.102.84):
In Reply to: Re: IH 460 carb problem posted by ChadS on August 11, 2005 at 14:55:12:
Hello Chad ,
Thanks for your reply . Is the Brass Id tag still on your carb ? If so ;do the numbers coincide with the numbers I've provided ? Would appreciate your sending me a pic . I'm definitely interested in your carb ,if in fact, it is the correct one . One recognizable feature ,is that the fuel line ,attaches to the forward side of the the carb .
I've found original issue carbs ,however, as you mentioned ,the trac then requires re modifying the installation . Also, the reason ,for the upgrade, was to eliminate the stumbling ,which occured with power changes . Was apparently a chronic problem of particular engines of the same displacement .
Thanks Again and will be looking forward to your reply .
WALT
wpstein98@aol.com
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
