Re: IH 460 carb problem
Posted by ChadS on August 12, 2005 at 07:11:16 from (66.228.96.197):
In Reply to: Re: IH 460 carb problem posted by Walt Stein on August 12, 2005 at 04:33:33:
Ill take a few photos and post them right here. The OEM carbs are a good carb, but each engine has its own characteristics in why they do the erratic things they do. I admit, the better carb like the one you speak solves about 90% of the problems, but, you could build that 460-560 carb to perform perfectly. it takes the right venturi, and fuel jetting to eliminate the famous IH 6 cyl stutter, Ive built Shebler carbs to work very well on these engines and have no stutter, just takes a little time to put it all together, and understand your particular engines specs,, like compression pressure, and knowing if there is any leaks of any kind that will create erratic conditions that these engines suffer from. Ill post the photo before the weekend it out. If you do want to build the OEM shebler carb, Ill tell you how to do it step by step. Chad
Post a Followup
