Re: Flushing the radiator
Posted by old on August 12, 2005 at 11:45:50 from (207.69.137.138):
In Reply to: Flushing the radiator posted by Florida Tom on August 12, 2005 at 11:08:14:
That depends on what you are really asking. If you mean spraying out the dirt on the out side or if you are talking out flushing out the in side of it. This is how I do the inside. I drain the system when cold, then fill with vinagar and run it for about an hour. Let cool and then drain again, Then with engine off I flush with a garden hose. If you can the best way it to make up an adaptor to hook the hose to the block drain and leave the cap off and let the water run for about an hour. Then refill with antifreeze and go.
Post a Followup
