Re: cub lowboy is spuddering and spitting under l
Posted by Rudi on August 13, 2005 at 17:01:12 from (69.195.156.80):
In Reply to: cub lowboy is spuddering and spitting under load posted by jbird on August 13, 2005 at 15:39:30:
Sounds to me like you got carb problems. Pretty simple to diagnose..
First thing I would do is check the Main Metering Jet- both holes - especially the little one in the end. Run a fine wire through, make sure it is not plugged.
Then check to see if a little choke will help. If so, most likely a air supply problem.
Have you checked the sediment bowl and made sure that there is no junk in the fuel?
Really sounds like a fuel supply issue..
Post a Followup
