Re: Farmall 200 disc brakes
Posted by VOLfarmall on August 14, 2005 at 05:14:24 from (66.19.139.39):
In Reply to: Farmall 200 disc brakes posted by Heywood on August 13, 2005 at 20:02:23:
You will need to know the thickness of a new disk, (this is important) take your old disk down to a clutch&brake relineing shop and have clutch lining material installed on the disks,also clean the actuator, check springs, balls etc take a small side grinder with a fine disk and go over metal surfaces. Take the one that is on the tractor off check seal and replace if needed. This will work. I have 3 tractors with dry brakes Have done this to all of them. Will cost a little more ,but its well worth it
Post a Followup
