Farmall 450 fuel delivery problem
Posted by CLoud rider on August 14, 2005 at 19:04:01 from (204.73.107.168):
Got a 450 farmall that mostly sits. Went to use it this spring and it runs like it has a plugged fuel filter; will run under load for a minute or two and then start missing terribly; let it idle for a couple minutes and it"ll run for another minute under load and then start missing again. Only problem is there is no in line filter; is there a filter integral to the carb? thanks in advance for any help. Mark in MN
Post a Followup
