Re: 350 Utility FLUIDS/OIL AMOUNTS
Posted by TDK on August 16, 2005 at 20:51:54 from (205.188.117.73):
In Reply to: 350 Utility FLUIDS/OIL AMOUNTS posted by Josh Johnson on August 16, 2005 at 18:43:32:
Hyd. System holds appox. 13 1/2 qts. (13 3/4 if equipped with power steering)& is filled/checked underneath the seat. Trans/differential holds appox. 7 gals. & is filled on left side of gear shifter, checked at plug on left side of trans,under the foot rest.Independent PTO holds appox. 2 qts., check.fill plug is located on left side of pto housing. All the above use C/IH Hy-Tran fluid unless tractor has no T/A. In that case then gear oil can be used in trans.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
