Re: 454 problems
Posted by jossette on August 18, 2005 at 15:38:34 from (216.114.223.157):
In Reply to: Re: 454 problems posted by Galen on August 18, 2005 at 15:30:49:
probably the screw on the bottom of the carb, needs to be turned out. you can do this while it is running....
Post a Followup
