Carb for H, Sh,W4
Posted by GordoSD on August 20, 2005 at 06:01:39 from (64.68.166.234):
Looking to rebuild a carb. But i NEED A KIT THAT HAS THE INLET FITTING COMPLEte with the strainer and the fibre washer for that fitting. I can't seem to find a kit that has that strainer fitting. It is soldered onto the brass fitting. Is is available seperately?
I also noticed that the same fitting works on all the IH carbs from 39 t0 54, H through SMTA.
Gordo
Post a Followup
