Super C drawbar / drawbar support
Posted by leon on August 21, 2005 at 03:30:40 from (12.219.17.84):
Saw a Super C with the more usual swinging
drawbar support that bolts to either side of the
rear of the diff case. But, along side, not yet
attached was another drawbar or drawbar
support that clamped around the rear axles
and was a big "U" shaped strap that goes
around the smaller support. The drawbar
itself wasn't on the tractor yet either but it
looked to be adjusted to be long enough that
perhaps it was supported by both the inner
and outer drawbar supports. Have I got this
figured out about right? Was this outer "U"
shaped strap/support/drawbar an option?
How common was it or did all Super C's have
it?
Post a Followup
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
