Posted by Janicholson on April 07, 2009 at 06:23:12 from (199.17.6.128):
In Reply to: Battery Drain posted by Tom in Iowa City on April 06, 2009 at 20:24:11:
The soldering may have allowed some conductor to touch the electrical box metal. There are no internal grounds in the box at all. The light switch is a ground through its field control circuit. (all positions of the switch go to ground the field circuit. (see the diagram) The switch has a light control circuit that is seperate from the grounding ofthe field. When in L the field is grounded through a wire wound resistor (which may be toast now) The field is in Low charge when in the L position. All other positions are high charge. If you accidently wired a light supply wire to the Field terminal, it would give those symptoms, and burn the resistor. Let us know, and good luck. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
