Re: another Super C bull wheel/axel question
Posted by a c hodges on August 22, 2005 at 22:13:10 from (4.227.63.104):
In Reply to: another Super C bull wheel/axel question posted by Leo S on August 21, 2005 at 19:35:03:
The 1/4 inch play is not normal. The washer with the holes pulls the axel tight against the inside bearing. The bearing is held in place with a retainer that bolts to the axel casting. I haven't come accross one with a snap ring but if it has a groove it should hold it tighter than that. Could be a screw up at the factory. Maybe the bolts broke flush with the hole and the washer is in the bottom. The axel can't come all the way out because the outide bearing will hold it in. If is has worked this long might be ok if left alone.
Post a Followup
