Re: Farmall Cub - carb fix?
Posted by Bronson on August 23, 2005 at 16:39:26 from (209.240.205.63):
In Reply to: Farmall Cub - carb fix? posted by James in MO on August 23, 2005 at 15:09:44:
I have fixed 2 of my Cub carbs by doing what you first thought of. Take the nut you wanted to put under the flange and grind one side of it down for just enough clearance that the nut hole threads will accept the stud or bolt going through the 2 mating pieces. You can still use a wrench on the bottom to hold the nut.
Post a Followup
