Re: Increase Farmall 100 RPM?
Posted by used to be scotty on August 24, 2005 at 05:04:03 from (199.231.50.128):
In Reply to: Increase Farmall 100 RPM? posted by Pierre Theriault on August 23, 2005 at 17:41:31:
Pierre, When the speed contol lever arm on the govenor is all the way forward, your carb throttle adjustment arm should have the carb all the way open. The threaded clevis arm is your adjustment, simply back off the locking nut and adjust the clevis to open the carb all the way. Hope thats clear. Let me know how you make out.
used to be scotty
Post a Followup
