Hard Starting 806
Posted by Ryan on August 24, 2005 at 05:58:26 from (66.82.9.52):
I have two 806 diesels, both have a fair amount of blowby, one has a turbo one does not. One tractor will start with 2 revolutions of the engine, the other I can barely get started. I have checked the timing, they both appear to be timed exactly the same (12 degrees at 50 degrees on the flywheel). I have changed the fuel filters, the oil, etc. and the injection pump and injectors are new. I have checked that there are no stuck valves. Any other suggestions? Can someone tell me what the valve clearance should be cold and if this would cause it to start so hard? It will roll over and act like it wants to go (it speeds up) but just keeps rolling over. I have also replaced the air filter with a new one.
Ryan
Post a Followup
