Re: Hard Starting 806
Posted by Jim Allen on August 24, 2005 at 09:11:16 from (209.173.160.22):
In Reply to: Hard Starting 806 posted by Ryan on August 24, 2005 at 05:58:26:
I agree with Allen. It's time for a compression
test. A valve adjustment won't help, unless all
of them are tight. In that case, you've got
burned valves too. Excessive blowby is a sign
of badly worn rings. A cylinder leakdown test
will pinpoint the rings, but you can find out with
a compression gauge too, by doing one test
dry, then pumping in a few squirts of 40wt oil
and doing it again. Compare the readings. If
the reading goes up substantially with the oil,
you have definitely got worn rings.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
