Re: How do you begin?
Posted by El Toro on August 24, 2005 at 14:57:26 from (205.188.117.73):
In Reply to: How do you begin? posted by fishermanS on August 24, 2005 at 14:02:02:
I would use transmission fluid and let it soak for week or so. If the starter is still on the tractor I would hook up a good battery, it probably is a 6 volt system. I would just bump the starter every few days and see if the engine would move. You need to be patient. You can drop the oil pan and loosen the rod caps. May have water in the pan too. I restored an A and it was seized and I tap on the rods with a piece of oak. The A had wet sleeves and several pistons came out with the sleeves and 2 pistons came out w/o the sleeves. I put in a new sleeve and piston kit. I completely tore the engine down and steamed cleaned the block. Had the machine shop to measure and polish the crankshaft and they furnished the bearings too. Your engine should be torn completely down, degreased and have new cam bearings installed. The crankshaft needs to be measured and ground undersize if needed or polished. If it has a mag or a distributor they will need to be rebuilt too. That engine should be pulled off if it frees up and examine the clutch. I haven't covered everything, but this should get you started. Take some pictures of everything before you tear everything apart. Keep the bolts from each part of the engine separated and kept in cardboard boxes and each box identified what the contents were removed from. Hal
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
