Re: Farmall A Loose steering
Posted by scotty on August 25, 2005 at 04:52:24 from (199.231.50.128):
In Reply to: Farmall A Loose steering posted by Steve Chapman on August 24, 2005 at 22:52:19:
Steve,
You might also check the amount of backlash between the steering shaft worm and the worm wheel sector. Sometimes you can eliminate some steering play by removing the large hexnut on the fromt of the steering box and try some shim washers that are large enough to only contact the outer race of the bearing on the steering shaft and reinstall the hex nut and see how much play you get rid of. Also as Bob stated, make sure the arm on the bottom of the box is tight and no slop.
scotty
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
