Farmall A Loose steering
Posted by Steve Chapman on August 24, 2005 at 22:52:19 from (4.227.32.129):
Help! I need to learn how I can tighten up the steering on my Farmall A. Presently, you can turn the wheel 180degrees before the front wheels start to move. Do I need a new steering Box? Can I pull the shaft and replace the gears? If so, where might I look for the replacement parts? Any and all help will be greatly appreciated. Thanks, Ripcord TN
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
