Re: Carb Float
Posted by RustyFarmall on August 25, 2005 at 08:10:15 from (199.120.81.222):
In Reply to: Carb Float posted by Charles Park on August 25, 2005 at 07:26:52:
There are 2 specifications that need to be met. The first is float level. The float level is what closes the needle valve and stops the flow of fuel. To adjust the float level you will have to very carefully bend the float arm, in very slight increments until you have reached the desired spec. The second specification is float drop. The float drop will allow the needle valve to open enough to provide for a sufficient flow of incoming fuel, but not so much that the float touches the bottom of the fuel bowl. This is adjusted by bending the small tab on the outer end of the float arm, the tab actually contacts the needle seat. Again, bend in small increments until you have achieved the desired results. Both of these adjustments are equally important. It would be a lot easier to show you in person how to do it than it is to describe, but this is the best we can do.
Post a Followup
