Re: IH 340 Utility Electrical Problem
Posted by Janicholson on August 25, 2005 at 13:56:28 from (199.17.6.127):
In Reply to: Re: IH 340 Utility Electrical Problem posted by T. Allen on August 25, 2005 at 12:55:13:
Assuming 12v neg ground. Lets check the wires one time. From ign switch to resistor, from resistor to coil+ from coil- to distributor terminal (connects to movable part of points inside dist., and has lead from condenser attached inside) all insulators on that terminal are good and centered to prevent shorts. If this is whats connected, and no other added condensers, or wires (there should not be) then the second coil is also bad. The coil and the resistor in series to ground (through the points) will get hot only if left on for several minutes with the engine stopped and the points closed. If the resistor is "flaming", the coil has insufficient resistance (shorted). Any other wires on this circuit are wrong!!!
JimN
Post a Followup
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
