Re: IH 340 Utility Electrical Problem
Posted by JimN again on August 25, 2005 at 14:01:36 from (199.17.6.127):
In Reply to: Re: IH 340 Utility Electrical Problem posted by Janicholson on August 25, 2005 at 13:56:28:
If the charging system is suffering a melt down from a totally burnt regulator (inside the alternator) or outside if generator, the voltage can go to 20 or more volts. If this is the case the remainder of the electrical system is subject to meltdown, bulbs and all. Pull the Bat terminal (big one) off the alternator and try it that way, if coil tests good, and wiring is as in my post above.
Jimn
Post a Followup
