Re: 460 Hydraulic problem
Posted by Joe Evans on August 26, 2005 at 13:29:52 from (209.41.211.82):
In Reply to: 460 Hydraulic problem posted by Tom Tractor 66 on August 25, 2005 at 19:59:40:
From what you describe, I would say your pump is OK, but it is starving for oil. Look at it this way--take your loader for instance. You've got plenty of pressure resulting in good loader power. This means the pump is not bypassing internally. At low RPM, the pump does not move much oil, therefore it does not require much oil coming in on the suction side of the pump. On the backhoe, the smaller cylinders don't require as much oil (smaller cylinder volume)as the larger ones, so the reduced volume output of the pump will run these OK. However at high RPM, the pump moves a lot of oil (12GPM for a standard equipped 460), therefore a lot of oil has to be supplied at the suction side or the pump will cavite (suck wind) and introduce air into the hydraulic system on the pressure side of the pump. This introduced air takes up space where hydraulic oil should be. Since air is compressible, your loader is floating down--the loader's backforce is compressing the air. Sure sounds like you've got a plugged filter/suction screen and/or not enough hydraulic oil in the resevoir. MNScott: thanks for recommending our site.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
