Re: Cub not Charging right?
Posted by John T on August 28, 2005 at 18:54:58 from (66.244.90.98):
In Reply to: Cub not Charging right? posted by John M on August 28, 2005 at 06:51:26:
John M, if the Generator and Voltage Regulator are working properly,,,,,,,,and if the Battery is good even though it may be ran down some,,,,,,,,,and if the belts good n tight and shes wired correct,,,,,I would expect it to charge maybe 20 amps or so after start up but then if no lights are on to hover slightly in the + charge (maybe a couple amps) as long as your at least a fast idle BUT I WOULDNT EXPECT IT TO SHOW MINUS 2 AMPS DISCHARGING UNLESS SHE WAS IDLING REALLLLLLLLLLL SLOWWWWWWWWWWWWWW OR THE BELT WAS LOOSE !!!!!!!!!!!!!!!!! When shes at that minus 2 amps you speak of, is that at slow or fast idle?? and does she go up in the slight + charge as RPM increases?????? If faster RPM brings her up, I dont think I would worry to much yet provided the battery never needs charging. I wonder how accurate your ammeter is??? The battery should read 12.6 volts setting but then increase up to the 13 to 13.5 or slightly more at full RPM if the batterys okay and the charging circuit is okay. Is this a 2 wire cutout relay and light switch generator field current type control or a full fledged 3 or 4 wire Voltage Regulator system after you upgraded to 12 volts as you mentioned ??????? John T Nordhoff in Indiana, retired electrical engineer
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
