Re: SUPER C STARTER PROBLEM - NEED HELP.
Posted by farmallhal on August 29, 2005 at 15:40:35 from (64.24.35.16):
In Reply to: Re: SUPER C STARTER PROBLEM - NEED HELP. posted by John T on August 29, 2005 at 15:12:18:
Thanks John for your response. I'll check that all out but the starter is not locked onto the flywheel as I can hand crank start it quite easily. I'm certain it is the switch or starter motor and if the starter is as easy to remove from the tractor as noted by an earlier post I'll just remove it. We have a very good starter and generator man in town and repairs are quite reasonable. Had to rebuild my M starter a few months ago with sort of the same symptoms - problem was weak brush springs. They just aren't made to last a 100 years I guess. If IH had made them they might have but they are a Delco-Remy part. Thanks again for your response. Hal
Post a Followup
