Re: A generator queery
Posted by Bob M on August 30, 2005 at 03:58:55 from (151.190.254.108):
In Reply to: A generator queery posted by holcombwa on August 29, 2005 at 21:41:06:
I’d recommend a new wiring harness, voltage regulator, ammeter and ign switch - also a new light switch if the tractor has lights. In the long run you will be glad you did!!
The generator ball bearing is available at any starter/alternator shop - the same ball bearing is used in nearly all Delco generators and alternators built thru the mid-80’s – about $10. Likewise the starter shop can press in a new commutator end bushing for you.
Good luck – nothing looks better at a green tractor show than a Farmall!!
Post a Followup
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
