Re: Farmall H Rearend/Transmission gear oil
Posted by Janicholson on August 30, 2005 at 12:57:50 from (199.17.6.175):
In Reply to: Re: Farmall H Rearend/Transmission gear oil posted by old on August 30, 2005 at 12:34:14:
Old Has it correct. If the tractor is stored inside, out of all but casual rain, the oil will last several seasons, The platform (top of the transmission differential that your feet rest on) tend to leak water through bolt holes. The shifter may (it is said) leak water in as well. It has no breather and (I believe) as it is warmed in use, and cooled when stopped at night, the system breathes in damp air, it condenses and contaminates the oil, then breathes out dried air. Thus building up H2O in the system. If milky colored when drained it had water in it. I think heating the housing with an electric space heater, or putting some kind of magnetic electric block heater on it for a day once a year would evaporate out the water. Good luck with the H they are way cool.
JimN
Post a Followup
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
