Re: one more F-20 mag question
Posted by El Toro on August 31, 2005 at 15:39:14 from (205.188.117.73):
In Reply to: Re: one more F-20 mag question posted by Paul G. in Mn on August 31, 2005 at 13:51:10:
You need to look for a timing mark on the flywheel
or the damper pulley. Once you locate the timing mark put some chalk on it so it's visible.
You need to remove No1 plug near the radiator and have someone handcrank it over slowly until you feel compression against your thumb, then stop
the cranking and look for that chalk mark. Once you locate the chalk mark keep cranking the engine until the chalk mark is aligned with the pointer. You could use a big handle screwdriver after you feel compression by placing it in the
plug hole and watch very closely until the screwdriver stops rising. You don't want to drop
that into the cylinder. This is TDC for No1 piston. Your timing marks should be aligned too. Crank the engine very slow after you feel compression. Don't move the engine now.
Rotate the rotor on the mag to the No1 position
on the cap and install on the tractor. The rotor should point to No1 in the cap, if not you need to pull the mag and reinstall until it is at No1. Don't forget to remove the screwdriver. Reinstall plug and see if the engine will start.
Hal
Post a Followup
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
