Re: Farmall H cylinder head
Posted by Stan(VA). on September 01, 2005 at 05:31:28 from (4.248.35.219):
In Reply to: Farmall H cylinder head posted by SCK on August 31, 2005 at 16:52:27:
SCK, One thing I'd recommend to check (before pulling the head again) is your rocker arm side clearance. I had a similar problem on my Super H, it burned #2 or #3 exhaust valve, and turned out to be lack of clearance between the rocker arm, center oil sleeve, and one of the lever brackets. The trick was it didn't show up until you torqued the whole rocker arm assy down. For #1, it would be between the rocker arm, the lever bracket, and the expansion plug or snap ring (whichever is on that end). I would turn the motor to TDC on that cyl, and verify that you can easily rock the arm enough to feel the .020 clearance with your finger. On mine the rocker would move around fine until the shaft was torqed down, then got very difficult to move the arm. It was just enough that the valve would open and close, but as the engine got hot, and clearance went to it's min, the valve wouldn't close all the way. If you have a simialr problem, I had to disassemble the rock shaft and mill down that rocker arm bushing a little on the side to open up the clearance then the valve worked fine, and doesn't require pulling the head again ;) Just a thought, Stan(VA).
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
