Re: 10-20 engine replacement
Posted by El Toro on September 03, 2005 at 13:29:49 from (205.188.117.73):
In Reply to: Re: 10-20 engine replacement posted by ohioron on September 03, 2005 at 12:40:37:
This is the first time that I had ever heard of doing this to babbitted connecting rods. I had
Federal Mogul to rebabbiitt some connecting rods years ago. I don't think they do it anymore.
Kunkle's shop machinists are all ASE certified, some are master machinist certified. You could
call Kunkle and talk to Gary in the shop. He has been there over 40 years and he's in charge.
They're closed until Tuesday.
Have you been able to find a sleeve & piston kit? Thefordsonhouse has a gasket set for $135.00. The F-30 engine uses rod inserts along with shims to get enough clearance. These are scarce too and I'm not sure if the mains are inserts on the F-30. Hal
Post a Followup
