Re: Painting Farmall White C
Posted by CNKS on September 03, 2005 at 19:34:24 from (204.249.178.138):
In Reply to: Painting Farmall White C posted by Farm Girl on September 03, 2005 at 17:06:11:
The best procedure is to use an epoxy primer over bare metal, then topcoat the cast. Use the same epoxy primer on the bare sheet metal, then several coats of a sandable surfacer followed by topcoat. If you use all products from the same manufacturer, and follow the manufacturers instructions there will be no bleed through. Or, you can use a stand-alone sealer made by the same company as the primer you used. If you did not use hardener in your paint it is not cured, so it is probably best to chemically strip it and start over, in my opinion.
Post a Followup
