Re: Tractor Quit
Posted by El Toro on September 04, 2005 at 16:58:12 from (205.188.117.73):
In Reply to: Tractor Quit posted by nc140man on September 04, 2005 at 16:15:22:
I would replace the condenser to if that fixes the problem. If it doesn't I would pull the coil wire out of the distributor cap and with the ignition switch on have someone crank over the
engine while you hold the coil wire within 1/4" of good ground and see if you have good fire.
Check the rotor to see if is ok. Is it getting fuel? See if it will start in the morning after the engine cools. Hal
Post a Followup
