Re: polarizing?
Posted by John T on September 06, 2005 at 02:48:55 from (66.244.90.98):
In Reply to: polarizing? posted by holcombwa on September 05, 2005 at 21:50:31:
Holcom, 1) A generator works cuz youre rotating a coil of wire (Armatue) inside a Magnetic Field (Field). 2) When current flows through a wire, a magnetic field is created whose North/South Magnetic Polarity is dependant upon the direction of the current flow. 3) The North/South magnetic polarity of the magnetic field in which the coil of wire (Armature) rotates, determines the direction of curent flow in that coil of wire when a load is attached. 4) You "Polarize" the Generator (NOT the VR) by grounding the Gens Field post and then flashing voltage to the Armature post (where Field windings are also internally connected on Class A Systems). This draws Field current which imparts residual magnetism (via the electromagnetic field created around current flow in a wire) into the soft iron poles which has that certain and correct North/South magentic polarity. THEREFORE When you Polarize a Generator you impart residual magnetism into the soft iron field poles having the correct N/S magnetic polarity so the Generator will cause current flow and charge the battery in the right direction and electrical polarity. When the Gen first starts to turn and before the Battery gets connected to it (via the cutout relay inside the VR between its BAT and ARM terminals) it generates electricity in the correct electrical polarity so as to charge (pump current into battery) and NOT discharge (draw current out of battery) Some VR's are bi polar and work at either polarity (if wired correct) while others may not. I have read the direction of current flow determines the coatings on the relay contacts and while they can work regardless, they last longer if current flow is in the direction they were designed for. Clear as mud???????? John T Nordhoff in Indiana, retired electrical engineer
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
