A light switch
Posted by holcombwa on September 06, 2005 at 10:45:57 from (209.206.169.243):
Disassembled the light switch on my "A" this morning and after a fair amount of head scratching and much diagraming: figured out how it worked..... Except for the little round mystery box under the low charge resister. When on high charge, it seems like the resistor is still hooked up. Unless, when on high charge the mystery box has an internal switch of some sort that closes and allows a more direct path to ground. Anyone know what is happening in the light switch to change the charge rate from high to low? (I've got a four wire regulator so won't be using the switch for that function, but would like to know anyway).
Oh, also, don't have a fuse on the ignition switch presently and wondered if it could be ran though the fuse for the lights. All help is appreciated.
Stan
Post a Followup
