Re: A light switch
Posted by gene b on September 06, 2005 at 10:53:41 from (66.43.221.67):
In Reply to: A light switch posted by holcombwa on September 06, 2005 at 10:45:57:
Check your generator to see if the third brush is adjustable to regulate the out-put. I f there is a slotted screw head on the brush end that screw can be loosened and that brush holder will move. You dont want it any closer to the brush on the top than 3.5 bars. Moving the gap wider will decrease the amperage out-put. Like you said you will not connect the wire coming from the generator field.
Post a Followup
