Re: Farmall 200 steering leak
Posted by Haas on September 06, 2005 at 17:05:31 from (12.65.42.230):
In Reply to: Farmall 200 steering leak posted by Heywood on September 06, 2005 at 08:56:38:
I think the 200 is the same as the C and Super C. There is a seal in front of the universal joint on the steering shaft where the shaft goes into the steering gear housing (front bolster). There is also a bushing there. If there is any play side to side/up and down in the worm shaft, then the bushing needs replacing too. To replace, punch the roll pin out of the universal joint where it is attached to the shaft going into the steering box. Then take the bearing loose on the side of the tractor that supports the shaft that goes up to the steering wheel. Then pull the universal joint off the worm shaft at the steering box. There is a woodruff key there you must get out of it's slot in the shaft. Getting the universal off the worm shaft can be a chore. Take the grill off. Remove the plug with the hex on it from the front of the steering box. Now you can screw the worm gear and shaft (all one piece) with bearing out the front of the steering box. You may want to drain the oil out of the steering box first to avoid the mess as much as possible. Now you can pop the old seal out and pull the bushing out and replace them. My experience that seal is a bugger to get in straight. I've ruined a couple of them. You need a good flat tool to press it in with and make sure it is square with the opening. Check the ball bearing on the worm shaft to make sure it has no play. If it does, replace it to tighten up your steering. I probably left out something. Hope this helps. Good Luck!!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
