Re: Belt pulley speed??
Posted by gene b on September 06, 2005 at 17:25:33 from (66.43.221.67):
In Reply to: Belt pulley speed?? posted by Scott in NNY on September 06, 2005 at 13:04:53:
How fast do you need to run your pump as that will determine the sizes of pulleys needed you dont want to have to run the engine full speed to get the desired hy pressure and flow just figure on the BNs pulley at 900 at 2/3 throtle. I use the CHAR-LYNN power pacs on the pto and have both single and two-way hy@900 psi and 10 gpm works well. The CHAR-LYNN is not to exceed 750rpm.
Post a Followup
