Re: Farmall H oil gauge
Posted by CJ-maybe on September 09, 2005 at 11:36:46 from (69.221.239.193):
In Reply to: Re: Farmall H oil gauge posted by jimmer on September 09, 2005 at 10:21:05:
What Hal says.Gauges are usually 1/8,sometimes 1/4.3/8 is BIG.Tubing,later 1/8,early sometimes 1/4.Any good parts or fluid power shop should fix you up.I'm guessing you have what is very close to weatherhead 'threaded sleeve'-the nut on the tube has external threads? I've run into them on IH.Can't believe the dealer can't-or won't- help.Adapter is avalable or get standard compression adapter,cut end off line,use the new nut & sleeve.Just need the 2 sizes.HTH Chip
Post a Followup
