Re: end play on no 8 plow wheel hubs???
Posted by RustyFarmall on September 09, 2005 at 18:23:24 from (216.248.75.165):
In Reply to: end play on no 8 plow wheel hubs??? posted by Andy2 on September 09, 2005 at 16:51:10:
There is an apparatus inside the hub that will let you tighten things up a bit. Remove the cover and look in there. You may find that the adjustment has already been used up, in which case you will need to fabricate a sort of extra large flat washer to be used as a spacer. You do not want too much excessive slop in the hubs.
Post a Followup
