Re: What's the point.???
Posted by Haas on September 10, 2005 at 06:20:40 from (12.65.60.188):
In Reply to: What's the point.??? posted by stan2270 on September 09, 2005 at 18:13:25:
You can get a 3 point conversion for your SA from Worksaver. Website is worksaver.com Be aware that the SA with this hitch setup will lift a max of about 500 lbs. Also the lift range is somewhat limited as compared to a modern tractor with 3 point hitch. If you are using pto equipment, there could be some problems due to the offset PTO location, but in my experience most things can be made to work. Don't expect the hitch to work very well with a plow, but it will be ok for a light carryall, small three point disk, dirt scoop, lightweight blade, etc.
Post a Followup
